Space is really at a premium under my hood. I'm going to be hard pressed to find room for 2 batteries. Anyone running a single battery? If so, how is it working for you?
I can get a single battery (Odyssey dry cell) that has 925 cranking amps. Think that will be enough? I could go up to their 1200 amp version.
From their site -
Odyssey combines in one box the characteristics of two batteries. It can deep cycle as well as provide serious cranking power. These batteries are capable of providing engine cranking pulses of 1700a for 5 sec as well as 400 charge/discharge cycles to 100% depth of discharge (DOD). A typical battery can do one or the other, but not both. With other batteries such as Optima, you must decide between a deep cycle or a high power starting battery, but Odyssey does both.
The cranking power of a Odyssey battery is double to triple that of equally sized conventional batteries, even at low temperatures.
Also with simple constant voltage charging, there is no limitation on the inrush current. This means you can charge your battery with as many amps as your charger, alternator, stator, or generator can put out as long as it doesn't exceed 15 volts. Lead acid, gel cell, and other AGM batteries can only accept 10amps per hour during charge.
[ 08-15-2005, 04:02 PM: Message edited by: JeepSJ ]
