Results 1 to 20 of 109
Thread: 6.2/6.5 Fluidampr?
Hybrid View
    Thumbs up 6.2/6.5 Fluidampr?
    Good news! Had a discussion with the folks from Fluidamper while at SEMA. They are said to be developing a damper for the 6.2/6.5...
    Cost will be $400-450, but will be a one-time purchase. They don't wear out or deteriorate over time like the rubber elastomer OE versions. I'll post more once the info is assembled...
    Apr 2004
    Palm Beach, Florida
    Default You made my day
    I'll be doing the t-chain sometime in near future so this is good news to me!
    Jan 2006
    Louisville Kentucky
    I thought it was already out and available. is it?
    1994 chevy turbo diesel 3500 4WD extended cab.
    4 inch Pinnacle exhaust from the turbo back
    Kennedy OPS harness (yet to be installed)
    FSD cooler (yet to be installed, planning on placing in fender to pick up air from intake)
    Bet top extendable mirrors.
    Lubbock TX, USA
    I've seen the "prototype" plastic mock-up version. Still some bugs to work out, but they're definitly making one.
    J
    If you check on their website under "Duramax" there has been a part number listed for the 6.5 as well - http://www.fluidampr.com/DURAMAX.htm
    According to the seemingly knowledgeable fellow I spoke with in LV, the 6.5 damper isn't quite ready for prime time, but is close.
    I was interested in their findings that the performance crowd routinely sees elastomer OE type damper failures on competition engines. Seems the increased stresses exact a toll on OE dampers, but the Fluidamper is unaffected on those same engines. Is it worth the asking price for use on a daily driver?
    Arrow FD Update
    The 6.5L Fluidamper is now available. As mentioned earlier in this thread, I spent some time with the FD folks while at the SEMA show last fall. As a followup, I contacted them recently to learn how things were progressing.
    In a phone conversation with Dan Oddy (lead design engineer for the 6.5L damper), I learned that the 6.5L damper was a unique design, and was not based on another of their product line. The external balance and other features are unique. While he didn’t go into too much detail, I was told that there are a series of equations that FD uses to define the mechanical properties of any fluid damper, and their FD damper used on the 6.5L is no exception. They measure factors like crankshaft weight & inertia and others to help solve the equation. Obviously, using a damper designed for another engine wouldn’t work, due to all of the various factors not matching.
    Dan mentioned that he was well aware of the problem some owners have had regarding the 6.5L cast iron crankshaft, and he said their damper should reduce the breakage.
    I was told that on a stock 6.5L application, we should be able to measure approximately 5% additional horsepower and torque – when using their fluid damper. This is so because the many and varied orders of harmonics present in a crankshaft during operation are more effectively dealt with in an FD damper, where a rubber isolated damper only helps control harmonics over a more narrow range. Harmonics can counter the force applied by a particular rod and piston while in operation. Reduce or eliminate those harmonics, and you get a small bump in hp/tq.
    I was also told that Jamie Avant of The Diesel Depot in Georgia and John Ayre of Dyna Droit diesel are evaluating production samples.
    Jim Bigley
    Nov 2003
    COLORADO
    I've heard both good and bad about the FD. John @ dyna droit swears that on his Dmax it idles smoother and helps quiet the engine down. I've never talked to anyone that actually has installed the FD on a 6.5 though.
    red '94 K3500 old faithful
    black '93 K3500 daily driver
    '83 G20 conversion van
    Nov 2005
    Lake Havasu City, AZ
    [QUOTE=More Power]
    [FONT=Verdana]I was told that on a stock 6.5L application, we should be able to measure approximately 5% additional horsepower and torque
    Lubbock TX, USA
    Lemme get this straight...
    6.2L application? Does this come with a spacer for the crank because the 6.5 balancer typically has the shorter shank because of the reluctor wheel?
    Curious as always, If it's truely smooth, this would be great for the 6.2.
    J
    Aug 2000
    Riverside, CA USA
    I am with the previous poster. Stating 5% is nice, but provide some test data. If it took that much engineering to design the damper, you would surely test an engine or two before and after the installation. Testimonials are nice, but hard data is better!
    Quote Originally Posted by Craig M
    I don't think HP/TQ testing is worth the cost and time. Dyno plots are subjective, anyway. Any power gains to be had will be a bonus, if even realized. The focus of the design is functionality. If a power gain is there, consider it a perk. It doesn't appear they are using it as a selling point. A 5% gain is not going to justify the cost of this product, but it does indicate a balanced engine operates more efficiently, which is not news. I seriously doubt anyone will demand a refund because they didn't get their 5%, which was never promised in the first place.
    Aug 2000
    Riverside, CA USA
    Jims post was that Dan Oddy of Fluiddamper made the 5% statement. For Dan to make that public statement, to a know diesel admistrator, to me means he should have some data to back it up. Dan mentioned in his testimonial post that he is going to get some data. Dan brough it up, now its time for him to show it. 5% is not much, but that and a smother engine might sell a few of them.
    Craig, Actually, IIRC my conversation with Dan went something like this:
    Jim to Dan: I remember seeing some FD information while at SEMA that mentioned a small increase in power after installing the FD.
    Dan to Jim: Yes, on a stock diesel, we typically see on the order of a 5% increase. That percentage can change, depending on how modified the engine might be.
    The power increase discussion was a very minor point in our conversation. I am primarily concerned with whether the FD can reduce the crank failures we hear about. I know from reading a lot about crankshaft harmonics that if a product can reduce the amplitude of those harmonics, it should be a good thing. That's my main interest. If we also see a small bump in power, as DmaxMaverick mentioned, that's just a bonus - not a major selling point. There are less expensive ways to get 5% more power.
    But, as mentioned earlier, we/someone will try to verify the power gain. If I'm involved, it will be as thorough and fair a test as I can think of, and I'll report exactly how the test was performed and whether there was a change in power.
    Quote Originally Posted by john8662
    J
    Yes the 6.2L application (p/n 800191) does come with the spacer to make up for the shorter hub length because of the reluctor wheel on the newer engines. if you do not need the spacer the p/n is 800141.
    The design intent of all Fluidamprs is to reduce torsional vibration from the crankshaft to increase the life of your engine & internal components. Any power gain is purely a bonus as it has been stated. In general we see a 5% gain in power, this is because we are properly controlling crankshaft vibration which allows the engine to run more efficiently.
    We have seen some applications have basically no power gain & in some we have seen a 10% gain. It just depends how effective the stock rubber damper is when it was originally designed. If the OEM did a good job designing the rubber damper there is only so much more left on the table that our damper will be able to pick up. If the OEM did a poor job in designing the stock damper there is much more our damper can gain. Since we entered the perofrmance diesel market we have noticed that the stock dampers were not designed well & in many cases are overworked. Rubber dampers are limited in how much vibration they can absorb. A fluid type damper can absorb much more vibration due to the silicone fluid that is used.
    Right now I do not have any data that I can post on the forum however I am working with Jim & will be contacting him later to possibly set up an independent test so that we can post hp & torque data with our Fluidampr for those who would like to know.
    I apologize for any confusion I may have caused about the 5% power gain statement as this was meant to be a general statement. if any one has any other questions I would be happy to try & help.
    Thanks,
    Dan
    Dan Oddy
    Sales Engineer
    Fluidampr / Vibratech TVD
    Jun 2006
    St. Albans, WV
    Interesting, but OUCH! $470!
    I don't think it's worth putting one on my 260k mile engine, but maybe if I build one someday I'll consider it.
    I have a chassis dyno, so if I ever put one on, I could probably tell if it made a difference.
    Lubbock TX, USA
    Thanks Dan!
    Now I can properly recycle my old 6.2L balancers! I had in the back of my mind to keep them just in case I need to cut off the hub to adapt to 6.2L.
    J
    1986 C10 SCLWB 6.2TD 3.73 700
    1989 V20 SUB 6.2NA, 3.73 400
    1994 G20 VAN 6.5NA, 3.42 60E
    1996 K30 DRW 6.5TD 4.10 80E
    Nov 2006
    pa
    Yea the FD is a nice product. When I got mine I was impressed on how nice the fd really came out. Right now it is just sitting around collecting dust Since I have no need for it at this time .
    95 suburban 2500 4x4
    6bt
    47 re
    373
    under construction
    6.5 parts for sale
    http://home.dejazzd.com/jkauto/6.5%20PARTS%20PAGE.htm
    MY SUBURBAN INFO HERE
    Sep 2000
    usa
    How about a front and rear pic of that bad boy, directly into the hub, for show'n'tell?
    Maybe even include the oem hb?
    jd
    May 2002
    Long Island
    I want one regardless.
    Fluidampr makes a nice product.
    With or Without 5%...
    I have had only good luck with them in 20+ years.
    Have never been down the track in my BBC without one.
    Even have contingency check stubs to prove...
    Billy
    '97 CC Dually INTERCOOLED 6.5 - Sold
    '06 Extended Cab/Long Bed LBZ
