I have a 93 GMC 3500 2wd Dualy. The trans stopped shifting into overdrive, for a while I could cycle the ignition switch a couple of times and it would shift into over drive, but as soon as I would let of the accelerator it would fall out of OD and not go back. I have tried to pull codes using the latest scanner from Snap-On and all it said was that it couldn't comunicate because there wasn't a engine ECM. I talked to a local trans parts house and i tried the only two things they could think of. I replaced shift silinoids A&B, the internal and external wiring harnesses and nothing has changed. I have also tried adjusting the throttle position sensor.
PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
