Results 1 to 7 of 7
Thread: power steering pump pulley
    Ft Walton Beach Fl 32547 USA
    Question power steering pump pulley
    I need to replace the pulley on my 1994 6.5td since it has quite a bit of play.
    Can the pulley be replaced with the pump still mounted to the engine?
    Also, what tool do I need to remove the pulley from the pump?
    Thanks,
    Bill Lucas
    2001 3500 D/A EC LB stock
    1994 6.5TD Banks exhaust, EGT, Boost, Trans. temp,oil temp gauges.
    Member#3698
    St. George, Utah.
    Bill
    There is a tool for the pulleys of the A/C compressor and power steering pump. You can rent it from places like Auto-Zone or purchase it at some of same parts houses.
    Remember the pulley has to be the same as the one that came off. If there is enough clearence the pulley can be removed on the truck. The tool is about three or four inches long.
    Say hello to Silvia for us.
    Dennis
    2018 GMC Denali HD 2500 L5P.
    Smile
    Thanks Dennis,
    I think I will try to rent the tool and replace the pulley. The pump was making a noise like a bearing going out. On inspection I found the pulley had a lot of
    play, plus the serpentine belt was damaged.
    Tell Bev that Sylvia said hello.
    Bill
    Member#3698
    Are you sure it's pulley play, and not a broken shaft? They are prone to either. Anyhow, you'll find out when you get the pulley off.
    Sep 2000
    so, ca , usa
    Exclamation pulley
    i recently had a run in with a noise on my 97 that i thiught was the power steering it turned out to be the lower crank pulley had lost the rubber damper
    steve s <br />97 K 2500 sub <br />BANKS STINGER KIT<br />DURAMAX FAN/ intercooler/stud girdle
    Default Pulley
    DmaxMaverick
    Since I still have power steering I assume the shaft is ok.
    Thanks,
    Bill
    Member#3698
    Quote Originally Posted by William Lucas
    DmaxMaverick
    Thanks,
    Bill
    They don't always shear off completely. I've seen one that was driven for about 1000 miles with a broken shaft (what's that noise....Oh, well....) before it finally stopped (and so did the noise).
    Good advice to check the crank pulley, though. While you are there, check the balancer, too. Either of them can make mysterious noises.
