I'm confused by the procedure for adjusting the TV cable in my 83 GMC. The TCI webpage is verbatim from my shop manual:
Step 5 Adjustments of the TV Cable on a diesel engine.
a. Adjustments are made with the engine off. If equipped with cruise control, remove the control rod.
b. Disconnect the TV Cable end from the throttle lever.
c. Loosen the locknut on the pump rod and shorten several turns.
d. Turn throttle lever to WOT and tighten the pump rod locknut.
e. Lengthen pump rod until injection pump lever contacts the full throttle stop.
f. Release the throttle lever and tighten the pump rod locknut.
g. Remove pump rod from the throttle lever.
h. Reconnect the TV Cable end to the throttle lever.
i. Press in the Adjust Tab and move Slider as shown in Figure 3.
j. Release the tab and rotate the throttle lever to WOT and the cable will self adjust itself as evidenced by a few audible clicks. Release the throttle lever and check the cable for any signs of binding or sticking.
k. Reconnect the pump rod and cruise control throttle rod, if equipped.
l. If equipped with cruise control, adjust servo throttle rod to minimum slack.
m. Road test the vehicle. Under moderate acceleration your shift points should be close to the following:
1-2
