If the two lines running up the back of the bellhousing are not correctly secured, they rub on a seam on the firewall and leak real bad. Ask me how I know that!
You can replace the short piece of rubber tubing from above if you lossen the fuel filter and push it out of the way. Not esasy, but possible. Make sure the lines are secured when you're done...
