South Bend Clutch installed
Well, I finally saved my pennies and got a South Bend single mass flywheel with a single ceramic disk clutch. I started things Sunday night, figured I'd take it slow and easy so when the clutch got here I'd be ready to install. Over Sun and Mon night I got all the old stuff out and ended up with some free time which I devoted to waxing... That's another story though.
Today the clutch arrived via UPS so around 2:30pm I started the reinstall. Got done and ready for the test drive by 5:00pm. There were no leaks and the SBC performs flawlessly so far. There is slight gear rollover noise at an idle, but if I bump it up to 800 via high idle it goes away.
If you have a ZF6 equiped truck and are holding off on this because you don't think you're ready yet I'd recomend doing it. It's amazing what a difference a good clutch and flywheel make on driving enjoyment.
I ended up replacing the slave cyl for $139, the trans/transfercase gasket+transfercase output seal for $60, and the clutch for $1187 delivered. So for a grand total of under $1400 I have the drivetrain from the engine back good to go for as long as I can drive the pickup for. Like I said before, Well worth it IMO!
I got the clutch from John@ Dynadroitdiesel.com. I'd highly recommend John to anyone thinking about buying a clutch.
red '94 K3500 old faithful
black '93 K3500 daily driver
'83 G20 conversion van
