OK, Thanks. I will go back to square one and start with the orginal shim in the pinion housing. The housing is orginal and the new pinion gear has a +1. Not sure what the original shim thinkness is, measures about .020 with my vernier caliper, plus or minus .001.
Thank you for the clarification on the coast and drive sides, that will make a differance at what I am looking at.
If I question it I will post pics again. Thank you for the input.
1997 GMC Savana - 6.5 TD
1967 Jeepster - Stock
1986 Jeep CJ7 - Stock
