Results 1 to 11 of 11
Thread: OIL TEMP GOING UP TO 220 AND OIL PRESSURE LOW, -20 outside
    Petrella Guest
    Exclamation
    Hello, the temperature outhere right now is about -20 degrees, when i start my truck in the morning oil pressure is ok, oil temp is normal (i have a gauge) when i get going down the road, my oil temp jumps to 220 degrees, and the oil pressure gets real low(about 2 lines from red) my oil temp doesnt get that high when im towing a trailer in 95 degree weather, and its so cold outside its climbing to 220. I touched both oil lines to the cooler and both seem to be warm??? the only thing i can think of is a restriction in the oil cooler or one of the oil lines. ill wait till it gets warmer out and try it again
    Anthony
    1994 GMC K1500 6.5 TD 4x4
    Banks Exhaust system
    16x8 American Racing Wheels
    285/75/r16 BFG All terrains
    Alpine stereo System
    Alpine Alarm System
    Boost Controller
    Autometer Boost,Pyro,tranny,and oil temp gauges
    Fuel cooler
    FSD Cooler, from my GM Dealer
    currently 102,000 miles
    Feb 2001
    Missoula
    When you say that your oil temp is going to 220 deg., are you actually reading the stock temp guage in the dash? If so, the problem might be that your antifreeze is not up to snuff in -20 temps and highway speed airflow thru the radiator. I had this happen to a gas motor once down in New Mexico during a bad cold snap. It froze my coolant in the radiator causing high engine temps and the oil press. to drop. Hope this helps.
    Petrella Guest
    no no no, not the water temp, thats normal. I have an oil temperature aftermarket gauge
    tom.mcinerney Guest
    Sounds like no airflow thru cooler. Maybe frost collected on the 'pad' of dirt/dust/vegetable+insect remains on the radiator (or condenser) just aft of the oil cooler? {look behind cooler?}
    rjwest Guest
    Very rare to see in truck. But you may have congelled oil in cooler...... Heavy, dirty oil will restrict it. best clean out the cooler....
    Petrella Guest
    i change my oil every 4000 km, i use shell rotella. the oil has about 2000 kilometers on it, and the cooler is clean. you pull my dipstick and the oil is clear not black. But today was a lot warmer outside and didnt have no problem at all. When it was -20 outside, driving down the road at 65 mph would make that cooler feel like -60, so im just assuming i got some real thick oil stuck in there cause of the cold weather.
    Nov 2003
    colville, wa.
    I had this problem with my 89 with a 6.5. Although I didn't have an oil temp guage, I did have low oil pressure at 0 degrees and colder. It would start up and show 60lbs. but then about 1/2 mile down the road until about 3 miles the pressure would show 20 lbs and then slowly increase as the engine temp got to normal.
    I finally determined that the oil wasn't draining back to the crankcase fast enough for the pump to pick it up and thus was starving for oil. A change to Rotella Synthetic 5w-40 cured the problem. Last week it was 30 below, and no problems. This has become my year around oil of choice.
    Hope this info helps.
    tom.mcinerney Guest
    Anthony, Diesel Joe:
    Do you use block heaters?
    Kennedy Guest
    Sounds like maybe the cooler bypass valve is not functioning properly, or you have a large leak somewhere internally...
    Petrella Guest
    yep i do use my block heater, and its been warmer the last couple of days and everythings normal. Its supposed to drop back down to -20 tonight so i will check it again on the way to work
    Marty Lau Guest
    The airplanes I used to fly would have the oil pressure drop in real cold weather but not show signs of oil pressure drop on the engine. What would happen is that there was a very thin line that oil was in to send to the gauge for a pressure reading. The oil in the gauge line would get congelled and pressure indication would drop. The way we sovled that was to fill the line with hydralic fluid.
