With two LB7s now totalling nearly 350K miles, its probably time that I purchase a 'ready spare' engine, turbo, Allison, transfer case, etc. for the unfortunate (yet unavoidable) day that I have a major drivetrain repair to deal with.
Question: What is the most cost effective approach to repowering a broken, high-mile LB7 powered truck under the following circumstances? Is an LB7 spare advisable, or are there any advantages to using componants from an LLY or LBZ drivetrain? This will affect what spare I buy.
My thought is to buy a complete drivetrain like this,
http://cgi.ebay.com/ebaymotors/ws/eB...5703983&rd=1,1
selling the extra parts I don't need to defray initial costs, such as computers, harnesses, intercoolers, etc.
1) 'Bottom end' problem - crank, bearings, rods, etc. (Longblock/heads swap from LB7 or LLY donor, reusing all LB7 accessories, wiring harness, computer, turbo, non-EGR LB7 exhaust manifolds, etc.)
2) 'Heads' problem - cracked head, head gaskets, losing coolant, pressurizing coolant system, overheating, etc. (At these miles, probably swap entire motor similar to above.)
3) Turbo failure. (How interchangeable are LB7, LLY, LBZ turbos?)
4) Transmission failure. (How model year interchangeable are Allison 1000s, TCMs, etc.)
5) Transfer case failure. (How model year interchangeable are tcases.) I won't own floor shift models anymore due to higher rebuild costs and scarcity of donor used cases/parts.
