Ditto on disconnecting center Inj pump connection, played stealership game, in & out of the shop no code present so it must not be broke, so finally in exasparation & with guidance from another esteemed DP member, I pulled plug start attempted, no start set code, reconnected it drove back to dealer; that with previous multiple visits convinced them it was a bad pump afterall, got mine replace under warranty
Tim, 98GM K1500 6.5TD(L56/L65), Heath PCM,3.73 gear,4L80 tr,4" exh,Amz air filt&dual oil flts, Heath remote FSD, TDO-7 clone turbo, Heath fan clutch,mandrel crossover, pilar gage BST/EGT/TRN, remote elec fan tran cool,alum trn pan
