Results 1 to 2 of 2
Thread: Glow Plug Relay
    Sep 2003
    Kalamazoo, Michigan
    Question
    Recently bought truck so am starting to upgrade and service the various systems. Just replaced the glow plugs............now would like to add the 5 ohm-2watt resistor to the "c" terminal on the GP relay. Is this item under the fancy plastic cover? Is it easy to get at? Does this resistor really increase the glow time and facilitate cold starts?
    Thanks for the input.
    2004 2500HD LT Duramax LLY+Allison 2WD Extended Cab SB
    Cooper LTX265/75R16 tires
    Email vernj4@juno.com
    Dec 2002
    Cincinnati, OH
    Ref a post named "Did something wrong??????"
    I don't think you can do the glow plug relay thing
    on 94 & newer.
    92 GMC std cab C2500, Kennedy high flow injectors,port matched, Banks exhaust & gauges, intercooler, 97 cooling, Turbo Master.A means for a Toy
