The boot I'm referring to is the boot betwee the turbo and the uppper intake plenum (with the two clamps holding it on).
Out of the several times I've removed these things I've never removed the inner fender. I usually remove the rubber flap on the inner fender covering the upper a-arm (pop plastic push-ins with tool).
This has worked for one on both 2WD and 4WD trucks...
Hmm, the hayes tells you to remove the inner fender eh? I'll check that one out, have that manual too.
J
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
