NP208 and proportioning valve issues?
First of all, I need to know if anyone knows of a good rebuilding manual for an NP 208.
Secondly, I've got a brake issue. The truck used to pull to the right a bit when you'd get on the brakes hard, now thats gone away and the truck pulls to the left an incredibly dangerous amount when you just apply the brakes. I'm assuming my right caliper was not functioning so I tried to bleed the right caliper with my vaccum pump. The bleeder just kept sucking air with very little fluid coming out, it would never hold pressure at all, I just kept pumping and pumping and it never stopped. The left brake was working so I'm assuming the problem starts at my proportioning valve to my right caliper somewhere. I can not see where I have any leaks at any of the fittings, and I have not messed with them in quite awhile. So all I'm left with is a busted caliper or a busted proportioning valve. Anyone had this happen to them? I also developed a squeal out of that right caliper just before this problem developed. My brake pads are fairly worn, so it could be just that, but I'm not sure if the squeal and failure are unrelated.
Any help clearing this up would be much appreciated guys..
-Martin
'82 K5 "Durasaurus" Blazer, Newly rebuilt 6.2, 6.5 heads, 90 ld DB2, 6" Pro Comp Lift, 35" BFG Muds, Rustoleum Rattle Can deluxe
