Originally Posted by
burnoil
The engine was pulled because the Blazer that held said engine came off a car trailer at 75mph and proceded to do "cartwheels of joy" with its new-found freedom. Truck was pretty much just damaged goods at that time, but the motor etc survived pretty much unscathed.
What are the head gaskets made of on these motors?? Steel shim or composite??
Composite Gaskets, with an '86 Model, it's got some decent gaskets from the factory, no realy worries here. Sounds like the engine will be just fine to me.
burnoil
Bah, I wouldn't say it is leaking, but it has what I would classify as "greater than normal seepage". Doing it on the stand would probably be a hoot, but doing it on the hook shouldn't be too bad.
The only reason I'm reluctant to mess with the cam plug on an assembled engine is because the rear cam plug is what sets the camshaft end play. A trick I think will get you by should you decide to remove the plug (that will be fun with the cam inside) will be to get the new plug and tweak it a bit. That is, this plug is the same as a Big Block gasser, but, the way the plug is made it is bulged inward into the engine. So, take a flat surface and level it out first (no more bulge), then install this plug in the block the same depth as the original plug, shouldn't trap the cam this way. Be sure to use a good sealant for assembly though, like an Anerobic sealant, or the Brown "Aircraft" sealant, don't use regular RTV.
burnoil
Do these usually come out intact, or do they leave remnants behind?? I'm kinda hoping that by pulling the main caps and hopefully finding absolutely gorgeous bearings, that I can get the old one out and roll the new one in. Feasible or do the rope remnants require direct access scraping??
The rear main seal is a snap, the rope seal will come out in one piece and there will be little-to-no residue left behind. Just wash out the bore a little with some brake cleaner and blow it out with shop air and you're set to install the new seal and then the cap. Pay special attention to the instructions that come with the seal.
burnoil
Any thoughts on the injection pump/injectors?? I would assume there would be some sort of funk in it/them from sitting, but I'm not too familiar with these components (as opposed to Cummins components).
No problems here as well. There will be some air in the system from the engine swap, etc. As long as you take care to keep contaminants out of the fuel system during the swap (post fuel filter) then you shouldn't have trouble. If you do, then a simple pump replacement or injector renewal will be in order, which can be done simply in chassis. With 30k, the injectors will be perfect, the pump should work fine too.
To answer one of the questions that Robyn presented...
Early or Later 6.2? In 85 GM updated the rocker arm/assemblies to a stamped-steel type, so your 86 will have these inside already. The previous assembles were condemed because of a few breakages, Mainly in early 82 models, primarily due to the clips around the anchors to the heads (full "0" verses a "C").
J
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
