Was there ever an option for heated wingmirrors on the pre-2000 vehicles. Or is there any aftermarket options out there.
cheers
Nobby
cheers
Nobby
97 K2500 Suburban, 3.42, 245 Tires, Custom Oil cooling lines, Snorkel Removed and 4" Heath Exhaust and Crossover. TSM Rear Disc Conversion.
My Suburban had heated 5x7's. I recently switched to http://www.visionviewmirrors.com/etm...ction_page.htm
They're heated, also.
Nobby,
I use the same mirrors as Dennis. Mine came prewired for heating the surface, but my Suburban was not. The wires are neatly tucked up beneath the mount cover waiting .
HammerWerf
1999 k2500 Suburban Pyro, Tranny Temp, Boost, K&N Air Filter, +3.5 qt tranny pan. 190000 miles
1984 C20 249k miles DSG gear, SM-465, 3.73
1983 C30 CC dualie. 308K miles on Chassis, TH400, 4-45 A/C Looking for a TurboCharger
http://cgi.ebay.com/ebaymotors/98-99...mZ160097703365
$35 + shipping...
97' C2500 GMC Suburban SLT
