Thread: Are these used GEAR VENDORS worth my while
    Jul 2006
    New Orleans
    Question Are these used GEAR VENDORS worth my while
    150096755814 and 150096767196 The 2 sets of numbers listed are the Ebay auction #'s for two different gear vendors. I have no way to determine how long a gear vendor is supposed to last hence whether these GV's are worth my time??
    Any thoughts on the prudence of buying a used GV and what to look for?
    thank you.
    Apr 2004
    Palm Beach, Florida
    Default Gv?
    Visit GV site and research from there, theycan tell you how long one should last and how much to rebuild one if need be............
    Aug 2000
    Riverside, CA USA
    If a used unit has to be serviced be repaired to open you wallet. Likewise if you have to "buy" an adapter, open up. They expect your other adapter then charge you $400+. Pay more for a good working unit with the correct adapter if possible.
    Jul 2006
    New Orleans
    thanks for the input and i appreciate your time.R
