The girdle is still there and seems ok. This engine seems quieter but I never heard it before it was put into [I]Blazin[I], we are probably around 3000 miles and have done some towing with it. It is driven almost every day but normally not far my son uses it to go to school. I'll need to locate my drawing and get back with you.
1982 K5 Blazer(Blazin) 4x4, 700r4, start of modified exhaust, 6 inch tall filter breather with 4" snorkel,egt gage, main bearing girdle as seen in gridle thread
1985 Suburban(Labrat) 4x4, 3' dual exhaust, egt gage, opened intake,700r4 with alto clutches, beast sun shell,13 vane pump,and more,others in progress hence the name.
That would be great
1991 CK2500, 6.2 banks turbo, FourtGear built TH700R4, Dick Cepek 6.5" lift, 35" wheels
im looking for a girdle also
1976 m882 shortened with a 6.2 diesel, np205 and sm465 and HMMWV tires
1992 Jeep YJ wrangler (project) plans are: 6.2 diesel engine, SM-465, Np-205, Dana 44 front, Dana 60 rear
1989 GMC suburban, 6.5 TD, TH400, Np-241, dana 44 front , 14bolt rear with Gov locker.
1997 Kenworth T800, 3406 Cat 575 HP, 18 speed, 4 speed Aux, 3.73 rears
1986 K30 M1008 6.2 diesel th400 np208 4.56 gears dana 60 front and 14 blt rear
N/A? = Non-Aspirated? Not Available? Needs Air?
ΜΟΛΩΝ ΛΑΒΕ
Hi 82blazer are your the girdles still in use in running trucks? Have you had the opportunity to open up a motor with the girdle installed? It's been a couple of years now and we would like to know the results after the motor was running with the bottom end strengthened up. Thank for the posts.
1993 sierra 3500 drw, 6.5L DB2831 ground spring, 4000rpm, custom cold air intake, H1C, 3 inch magna flow stainless muffler, remote tranny & engine oil coolers with fans.
Still hoping to have girdle updates, anyone.....
Anyway, heres pics of our first on a 6.5L tdi....
No, sorry no pics yet, I need to first reduce their size to upload...
