i have a 1983 chevy 6.2 with a t400 tranny thinking about swaping it into my 1990 yj. Am i crazy? i know it it just like a reg 350 and more weight. has anyone here swaped one?
Yup.
Not into a YJ, but close enough.
You should check these:
http://www.thedieselpage.com/readers/fleming.htm
http://www.jeep2diesel.org/
I think it would be a good swap.
1997 GMC Savana - 6.5 TD
1967 Jeepster - Stock
1986 Jeep CJ7 - Stock
I actually purchased a 94 YJ last Labor Day with the intention of doing a 6.2L diesel swap. I just recently sold the Jeep, though, due to the fact that my wife and I are expecting our first baby.....something had to go!!
