Results 1 to 20 of 99
Thread: LMM Fuel Economy
Hybrid View
    Quote Originally Posted by craigth View Post
    Larger tires should NOT make that much difference in MPG vs stock tires! With the Duramax I should be getting at least 13-15 if not higher considering some on this forum claim 17-20, which sorry, I don't believe!
    What sort of fuel economy did you get with a completely stock truck, stock tires, stock programming, etc., and driving at a constant 65-mph on the Interstate?
    Dec 2006
    North Pole, Alaska
    Those tires are pretty heavy, that makes a bigger difference than most realize. Also, how far off is your speedo now? Make sure to take that into consideration.
    Mar 2008
    The lift kit won't affect as much as the tire size, With 373 rears and adding bigger tires the allision computer starts changing things, sensing the load from the tires it adjusts to more of a tow mode, changes the shift points and converter lockup.
    I know of a truck with 22.5's that won't go into full over drive lockup untill 25mph because of the matchup of tire to rear end.
    As always it takes a diesel a long while to break in compared to gas. It took about 17000 mi to notice a dif in my cat330
