Hello All,
Well I have a 93 with 285,000 miles.It's getting the 4L80(junk) rebuilt as I type.So the tranny problem will be fixed or the 12 month 12,000 mile deal will get it fixed again...LOL. I have only had it about 1 1/2 months and have drove it maybe 400 miles....No reverse,overdrive sometimes slips,smokes when cold,seems to have blow by on PCV valve(which is not connected to turbo tube) and blows a little oil on the engine...I didn't do it!!! The guy I got it from was a diesel mechanic for a trucking place,he said it needed a head gasket,he even gave me the new gaskets.He gave me a set of heads,heck I can see the crack between the valves...He said that didn't hurt them???I have built a lot of gas motors.This is the first diesel i have owned,I think the extra heads are junk.
So here are the problems...
1) It smokes a lot at start up,I have put a new controller on it (that helped)and have new glow plugs on the way from SSDiesel Supply.But can a head gasket cause this? I will get some injectors when I get more cash freed up.
2) It now seems to be pushing water out the overflow...BAD Head gasket
I have the gaskets and just waiting for it to come back from the tranny shop.
If they have any cracks I don't want to reuse them.He said it has never been hot,so they should be fine.It has never been over 210 when I have drove it,longest was about 60 miles.
OK after I get these problems fixed I want to do some little mods,Exhaust& Air filter, But I can't find a chip for the 93,I have read where you can turn the fuel up on this pump to get more power from it?How???? I will be using this truck as a welding truck 5 days a week and a racecar puller on weekends so it will get a workout. The tranny shop is putting a HD cooler and torque converter,some kinda HD shift kit it's costing me a lot @$1600 to have the tranny fixed,but the cab is great and I traded a wrecked vette for the truck.So I can afford to put some money in it to make it right.I'm putting a steel flat bed on it and a Lincoln Ranger 8 gas welder.I'll try to upload some pics,before and after etc.
Thanks for the help,
Tom K.
