You're right that you won't need the ECM.
I'd recommend finding a harness out of a Diesel truck of that year model.
But, you could still wire this engine up pretty simply, because it doesn't really require much, especially since this is going into a standard-shift setup.
You'll likely need the Diesel flywheel and components for the std shift conversion.
J
1986 C10 SCLWB 6.2TD 3.73 700
1989 V20 SUB 6.2NA, 3.73 400
1994 G20 VAN 6.5NA, 3.42 60E
1996 K30 DRW 6.5TD 4.10 80E
