No fuel pump for Duramax
Margo,
The duramax does not use a fuel pump in the tank, the CP3 pulls fuel itself from the tank thru the fuel filter and up to the pump.
Some folks add lift pumps on the frame rail to help the CP3 get more fuel. They will run the pump thru an oil pressure switch so the fuel pump turns off when the engine is not running.
TDP member #14
