Results 1 to 6 of 6
Thread: Wait to Start Light Blinking after start.
    Apr 2007
    Chicago
    Default Wait to Start Light Blinking after start.
    Driving this weekend my Wait to start light started to blink after the engine started to run. I would blink three times and then go out. I searched the forum and could not find any thing on this problem. What is the engine trying to tell me?
    1999 Suburban 2500 6.5TD Chicago, IL
    Most of these do.
    My 94 will do it a couple times quickly after the initial glow time.
    As long as the sucker does not stay on too long or keep on blinking its fine.
    The old 6.2's would cycle several times after the initial start up.
    This was done to reduce smoke during the first few minutes of run time.
    You generally see this more when the weather is cold on the later trucks.
    Hope this helps
    Robyn
    Michigan
    Don't worry, this behavior is normal. The PCM pulses the glow plugs briefly after the engine starts to keep the tips hot and engine firing smoothly. Colder temps results in longer pulse times.
    2016 GMC SLT 2500 CC 4x4 Duramax All Terrain 59K
    1995 GMC 2500 EC 4x4 6.5TD,236K,Custom Tuning,HX40W-II turbo,Amsoil Bypass Filter,KD Exhaust,FSD Cooler,KD Headlight booster,Hi-cap Cooling
    TDP member #14
    Jun 2006
    St. Albans, WV
    Yeh, they usually refer to this as "afterglow". It's normal.
    Apr 2007
    Chicago
    Thanks for the help.
    Default that answered my qustion too
    I was wondering if that was the case. This forum is great!
    thanks!
