According to my dealer, after taking the truck in for what I perceived to be some injector problems, my #1, #4 and #6 injector sleeves are leaking - those three at a minimum. This is my second set of injectors, the originals were replaced in Jan '06 at 96K miles. I'm now at 135K miles.
Has anyone else had leaking sleeves after injector replacement where the dealer only replaced the injectors (i.e. didn't touch the sleeves)???
Anyone had a leaking sleeve on the original set of injectors???
What was your experience/resolution? If it was after an injector replacement, did the dealer accept any responsibility for it?
According to Duramaster, he's only seen *one* instance where an original factory sleeve leaked, and it sounds like that was under weird circumstances.
The dealer says it'd be $2700 to replace the sleeves, and then they'll look at replacing the injectors.
I find it hard to believe the leaks are just a coincidence and have NOTHING to do with the injector replacement, as the dealer is asserting.
Scott
