Height on those tires are only about 1/2" different in total diameter. The main difference is the width, the 235 is about 3/4" (20mm) wider than the 215. The 215/85 tire, probably, is a higher load capacity.
The dealer or a tire shop should be able to look up what came stock on your truck, or go look at another truck of the same year and model.
1997 GMC Savana - 6.5 TD
1967 Jeepster - Stock
1986 Jeep CJ7 - Stock
