starting trouble
well i have a 1984 with the 6.2 in the morning i can go out and it will start up fine and glow plug light will come on. take it to work get off of work go to it it will start fine. get home shut it off go out to go some where and the glow plug light will not come on. it will crank and crank then finally start. the rest of the night glow plug light will not come on unless sitting for like 8 hours+. it has new glow plugs,glow plug reply and starter would could be my problem
Very often these issues are the starter.
A worn starter won't be able to turn over the engine at the RPM it really needs to bust off an run, especially in a no-glow situation where the engine's compression is making the start.
A dragging starter will hang on in there for quite some time too, making this issue harder to troubleshoot and resolve.
Also, good CCA batteries are also necessary for optimum cranking ability.
J
- You may not post replies
- You may not edit your posts
Forum Rules
