Dave,
The DS/DB pumps generate their highest mm3 output at about 2000-rpm. It tapers off to some degree at higher engine speeds. Probably has something to do with rate of pumping plunger recharge - not able to keep up at higher speeds. The marine DBs have slightly better flow rates above 2700+, which means they should be able to produce more horsepower (rpm is a factor in the numbers). I'd have to see the data sheets from a calibrated Stanadyne flow bench to be convinced of 100+mm flow from any DS/DB. I have the Stanadyne spec sheets for the DS and DB2 & DB4. None approach 100, at any rpm.
The original LB7 Duramax was rated at 91mm at 3400-rpm to deliver 300 horsepower, but it has a high-pressure common rail, which means fuel delivery is less affected by higher engine speeds.
Clear up the smoke... I plan to install a modified Holset HX35W on our newest 6.5 project... This one is efficient at 15-20 with cool EGTs, where the GM turbos are not - too restrictive. I'm not doing this (Holset) for ultimate power, but for better efficiency and fuel economy.
