Results 1 to 13 of 13
Thread: '72 Chevy 3/4 ton 6.2 conversion
    Jul 2007
    S/E Michigan
    Default '72 Chevy 3/4 ton 6.2 conversion
    I'm making plans to put my old Custom/20 flatbed back on the road that has a 4 speed manual trans and a Dana 60 rear. I'm considering picking up one of the 6.2L mechanical military take-out engines that are out there to replace the 350 and I was wondering if anyone who's tried something like this could tell me what I'd need to do this & if I'd be better off with a donor vehicle that has a running 6.2L instead... /// tim
    1998 VW TDI 190K d/d 47mpg
    1995 C3500 HD dually 6.5L TD (project)
    1972 C20 3/4 ton
    1948 Farmall H
    Jul 2007
    S/E Michigan
    Default Thanks!
    Thanks for the welcome, Jim!
    I read the thread you mentioned and my 6.5L books arrived along with my Helm manuals for the 3500 HD, so I have plenty of reading to do to prepare for my 2 projects. I was out disconnecting everything from the 6.5L in the 3500 so I can pull that one out over the weekend with some help.
    The 72 3/4 ton has a manual trans, so if I understand I should be able to bolt up to it, but I'm wondering if I have to make any changes to the existing gear ratio on the Dana 60 or if I'll be o.k. keeping everything the same as it was with the 350. I know this is an older vehicle than usually is used for such a project, so I'll keep reading though some of the older posts to find any more information on a similar switch done by someone already.
    I'm sure I'll learn quickly with all of the information that I now have available to me, and look forward to being a member of this group. /// tim
    May 2004
    Alaska
    Default '70 Chevy 3/4 ton 6.2 conversion
    Hi I bought a 1970 Chevy that a guy was trying to convert over from a 350 gas to a 6.2L diesel. He did not have much experence with this kind of project, so I picked it up. Anyway the engine was out of a 1984 K5 Blazer, and he tryed to use the engine frame mounts from the Blazer, this put the engine to low. I put the frame mounts from the 350 back in, this didn't work ether. The exhaust manifolds hit the mounts, so I had to get the frame mounts from a Big Block I used the engine pads from a 350 gas and this worked out good, hope this helps. John
    Jul 2006
    Manheim PA 17545
    Thumbs up
    I gess i`m in the right area. I`m working on a 6.5TD in a "72" K-20. right now I`m tring to figure where to set the motor front to back.
    Willis
    Sep 2003
    Feeniks, Aridzona
    Quote Originally Posted by 67-72williso View Post
    Willis
    Use the big-block frame mounts in the stock location.
    Jul 2006
    Manheim PA 17545
    Arrow Gear ratio
    Turbotim, the best gear you can get in a Dana 60 is 3.33 for diesel non OD trans applacation.
    Later, Willis
    Jul 2006
    Manheim PA 17545
    Wink
    JeepSJ
    I am using engine crossmember out of a "87" 6.2 diesel truck. It`s a little different mix of things. The turbo is on the back on this one to (van type).
    Thanks, Willis
    Sep 2003
    Feeniks, Aridzona
    JeepSJ
    Thanks, Willis
    I gotta ask - why are you swapping crossmembers? The 6.2/6.5 share the same engine mounting locations as the small block and big block gas engines, so it would have bolted right into the original crossmember. What are you hoping to gain by swapping the crossmember?
    Jul 2006
    Manheim PA 17545
    Default crossmember
    JeepSJ
    In 67-72 4X4 there were no BB installed the oil pan hits the crossmember. In 2 WD they used them in these years. So buy using 73-87 4X4 crossmember that should make that part work. I also put the front swaybar crossmember in to.
    Willis
    Burning Oil's Avatar
    Burning Oil is offline http://www.lubedealer.com/pmdcable/home.aspx
    Jul 2006
    Houston TX
    I ran into the front xmember hitting also on mine. A 1970 4x4. You are correct that they never came with a big block in the 4x4 in that body. I did put one (454) in mine and I used the xmember out of a 1974 4x4. I had to nocth it and reinforce it at the harmonic balancer or it would hit. Also I had to modifiy the fire wall. Not sure if these problems will pertain to the 6.5/6.2
    1993 4x4 1ton 6.5/4l80e runs on WVO.
    1996 1ton 2wd crew cab 6.5/4l80e with db2 IP.
    1996 1ton 4x4 crew cab dually with Cummins diesel
    1970 Chevy 4x4 big block 4 speed.
    1972 Chevelle convertible with 540 CID engine.
    We sell pmd extension cables and the Flight systems PMD or the new Stanadyne PMD with available 7 year warranty.
    Turbo Boost Bolts, engine oil cooler kits and lots of 6.5 turbo diesel parts. Check out the web site
    www.pmdcable.com
    Jul 2006
    Manheim PA 17545
    Burning Oil
    I understand the cutting of the firewall, because you didn`t move the BB mounting front to the the 2WD position. But I don`t see why you had to cut the crossmember if you used all the 73-up clamshell motor mount stuff.
    Thanks, Willis
    Jul 2006
    Houston TX
    I did this 5 or 6 years ago so I don't remember exactly now, but I think thats just the way it worked out. I do still have the truck and could take some pictures if it will help.
    Later
    www.pmdcable.com
