HI,
Does anyone have the pinout for a 06 Silverado Duramax Instrument Panel Cluster(connector)?
Thank you.
kai
HI,
Thank you.
kai
What exactly are you looking for? What is the problem? I am a Tech at a GMC dealer in the Pacific Northwest. Let me know what you need and I will do my best to help.
@Duramaster
I'm going to do a 06 Duramax engine swap and want to use a 06 Silverado IPC (from Ebay).
GM part# is 15101853. It has a 24-pin connector.
I only have 06 Express Van wiring diagrams - but the IPC connectors are different.
That is the reason why I do need the Pinout to get the new IPC working.
Thank you from Germany.
Kai
Nobody??
Thank You.
Kai
Kai,
You should be able to get the pin out from www.alldatadiy.com (requires a subscription) ... I have subscriptions for all my vehicles .. basically it's an online factory service manual .. also includes access to TSB's
Bill
98 K3500 6.5,SOLD
