I am not a fan of power adder that switch power levels , the allison needs to relearn how to handle the power after you change it. 9 out of 10 times the power gets added and no one lets the trans relearn and it slips into gear at each up shift . If you want to keep his truck heathy tell him to keep the power levels below 80 hp added and leave it there .
I have kennedy diesel custom 70 hp tow/perf tune in my lbz truck. everyone thats driven the truck cant tell its not stock until you hit the go peddle. about 2 mpg better economy empty or towing. I run with a stock ECM under the rear seat in the event it needs to see the doctor, I just swap them out... Transgo Jr kit helps the new 6 speed shift , it will not make it handle anymore power then stock. Give JK a call or email him , IMHO its the way to go . I had 2 othere trucks with Juice , I am not going back. At 70 hp that JK claims it has more power then juice on 3 and way more lowend TQ !
93 c-2500 6.5td,96 6.5td x cab,01 GMC lb7 Xcab ,2004 lly crew cab ,2006 lbz crew cab,honda CBR1100xx,2003 polaris prox 700 , 2001 31' holiday rambler 10K lbs house on wheels!
