Hello.
I installed the bully dog shift kit on my trany. And now the car want go in gear. What have I done wronge? should I fill the "box" whit oil before I reinstalled it?
Hope someone can help me.
Utsi
Hello.
Utsi
*Silverado 6.5 98; crom bumper, side step w/ markers, bedliner, ganster cap w/ markes,
* Duramax 6.6 03; crom bumper, Sidestep,ganster cap, rollerbar, bedliner. 5" exhaus, programer.
sounds like solinoids are not pluged in or something put in wrong ????? is the dash indicator flashing?
There are no ligths flashing.
I think a should bee correct installed. But I didnt fill the box whit oil before reinstalling. It could be one of the contact.....
how can I install the solinoids wrong?
If it is low on fluid, it will not shift correctly, and may not go into gear at all. Fill the level to "full cold". Warm it up and check for proper level before trying to drive it. Serious damage can occur if you try to drive it too low on fluid.
The fluid level is ok. So thats not the problem. I have checked that.
Which box are you talking about? Not the NSBU, I hope.
The box you gets to when you have taken the oilfilter away.
is the box whit the solinoinds on.
Utsi
It could bee. I dont know the name of it. Is in that box I installed the shift kit. (2Springs and 2pins)
Utsi
Sounds like you may be talking about the transmission pan (or sump). If that's the case, the dipstick will show how much fluid is in it. If you aren't seeing a Service Engine Soon light or the gear display flashing, the electronics should be good. I suspect you are too low on fluid. If you removed the pan, you would have had to remove a lot of fluid. It must be up to the correct level.
I have added the same quanty of fluid, as I got out.
The gear indicator in the display flash. So there is an electronic error?
Will do that to morro. Live in Norway, so its bed time here now. Thanks for great help. Will check my conctions to morro. Hope it will help.
Utsi
Hadd my "box" down to day. The problem was that one of the new valves was a littlebit to big. After some polishing it runs great. So now my baby are helty again!
Utsi
