Hi
New here, but owned several 6.5 for 10 years.
Have a 98 ext cab C2500 4x4 6.5 TD quit quite strange, driving down the road, started to heat up a bit, then just quit. No knocking, No bang, just quit. Temperature continued to rise after truck quit.
Tried to start right away, nothing. Tried an hour later, started but, barely, ran really, really rough and lots of black smoke.
Any area should look for easy or quick fix or assume the worse, rebuild motor?
Is there a way to check for codes without scanner?
Hoping it might be timing issues
Truck has 405, 000k, but bought used , so do not know if it is original motor or not
Any help appreicated
Larry
