Thread: Tow Mirrors on a NBS 2007
    Default Tow Mirrors on a NBS 2007
    Does anyone know if GM part number 15904034 will fit or work on a 2007 NBS 2500?
    Quote Originally Posted by tksmitty View Post
    i had just purchased a 2007 nbs 2500hd and replaced the mirrors with the towing mirror package. when you talk to the parts counter have your vin with you. there are several different models of the towing mirrors and they will need to match up what will work with your truck. the mirror set is not cheap, around $450.00 bones. they will come with destructions on how to install but it was not hard. you will have to pull the whole door panel off to hook up the wiring to complete the install. it took me about an hour to complete. the only tools needed are a 10 mm socket for all the bolts on the door panel and the mirror mount and a sharp screwdriver or knife to remove the door lock from the panel and the bolt covers. hope this helps
    Wetumpka, AL USA
    Mirror replacements from GM Parts direct
    http://www.gmpartsdirect.com/results...umber=19202235
    They list part number 19202235 as a replacemnet set for the base heated power but no power fold mirrors. Price $381.15. i think they have some others as well. you need to go to acc. then drill down.
    Bryan
    00 Dodge 2500, 4x4, QC, ST, Cummins 24 valve ISB, Jacobs/Cummins Exauhst brake, Dual Pyro and Boost guage, 12 JVC CD
    Wetumpka, AL USA
    They list part number 19202235 as a replacemnet set for the base heated power but no power fold mirrors. Price $381.15. i think they have some others as well. You need to go to acc. tab then drill down.
    Bryan
