I'll forgive the sad misuses of my name.
Anyway, rust isn't forever, even on a GM. The offending area should be sanded to remove as much as possible, then as prior posts, a phosphoric acid primer should be applied. When dry (~24 hours), the excess should be removed with mineral spirits and the area sprayed with cold galvanizing spray (three coats). Then the topcoats.
Of course, with an all-aluminum motorhome, I don't sweat corrosion...but I do share your pain...
