Results 1 to 7 of 7
Thread: Electrical question
    Jun 2007
    Watkins, CO
    Default Electrical question
    2003 2500HD Crew Cab, D/A, very base model.
    This morning when I got to work, the right (passenger) front door had no power, no power lock, no power window, from either the driver or passenger control. It was OK when I left the house, because I rolled up the window. The accessory delay doesn't work either, the radio and windows shut down immediately when the key goes off. Also neither remote key fob will work.
    A quick check of fuses (without pulling them) doesn't show any obviously blown. Can all these problems be related to one circuit?
    Thanks,
    Bob
    tufcj
    Jun 2007
    Watkins, CO
    Deeper check last evening, I tested all the fuses in the dash panel and under the hood. All good. I also notice that the dome light doesn't come on when the passenger front door is opened, and the passenger power mirror doesn't work either. I unplugged/reseated the left door harness at the dash fuse panel, that did nothing. The rear passenger door works fine.
    A friend suggested maybe the computer needs reprogramming?
    Anybody got any suggestions before I take it to the dealer? I don't have much confidence in either of my local dealerships.
    Bob
    tufcj
    Not much to go on "hands off". Check your RAP fuse (again), and the RAP relay. 01/02 has one, I think 03+ has 2, one for each side.
    May 2000
    MA
    Bob,
    The Retained Accessory Power (RAP) relay permits the operation of convience accessories when the ing switch is cycled from an on to a off or lock position. Its a single pole/double throw relay. When the truck is running, the relay is denergized and the closed contacts (NC) powers devices in the truck. When you shut your truck off, this relay is energized and the other contacts close, maintaining power to various accesories until you open the drivers door. The Body Control Module (BCM) controls this relay by grounding its coil when recieving commands from the ing switch and door jamb switch.
    When you shut your truck off, you should be able to hear this relay energize when you open the drivers door (turn the radio down and watch the light on the radio). If the relay is not actvating, you should be able to test the coil power and ground contacts at the relay socket with a test light.
    I suspect you have a problem with the door jamb switch and/or wirring inside the door. You stated that the dome light and LH power mirror are not working. These devices are not part of the RAP circuit, but are part of the door wiring harness.
    Any dealer with a scan tool can troubleshot this pretty quickly. If you have a problem with the BCM, the dealer has to change it because they have to configre the new one. On a 2001, the BCM is located below the steering column behind the "knee bolster".
    MEP<br />01 2500HD, LB 4x4 Dmax w/ZF-6 spd., SBC Solid Steel Flywheel<br />DP member #739
    Jun 2007
    Watkins, CO
    Here's what I got from a GM tech that a friend knows.
    The right front switch on your truck is actually the rf door module and controls the keyless entry, window and door controls and probably keeping the retained accessory power from working. You quite possibly have a bad module on the right door. You will want to check all the powers and grounds to the module, if they are all there you will need a new module and it will have to be programmed when you replace it. Hope that helps.
    Default here's a twist
    I have a 99 S10 that is acting like the door is open/unlatched. I have no pwr to rap features once key is off, dome light stays on with doors closed & override button out. Keyless entry works fine so does pwr locks, windows on both sides. It sounds like its not making a door connection. Door chime goes off with keys in ignition door closed, dash "security" light go off when doors are closed. ??
    Thanks,
    TA
