Ok so the starter went out on my old 24 volt military 6.2
I replaced it with a starter i had lying around. Must have been a 12 volt because it only lasted about a month before it died / melted the main link from solenoid to starter in two.
So i ordered a "new" 24 volt starter. I installed it. Nothing not evens a click from the solenoid. So i get out to see if i overlooked something; to smell plastic burning, see smoke from starter area, and find the solenoid to hot to touch still melting down with the key off. Had to pull the battery connection to alleviate the problem. I take it off and it has melted the solenoid down internally.
It has been working the way it is wired for about three years before initial starter failure.
So my question is: Do i have a problem or just dumb luck lately??
One starter died / two melted down.
I have noticed a lack of a real good ground from batteries to engine block.
Also why is it wired in series twice?
The first battery runs to the second and then to the junction block; and there is another wire from the first battery to a lower junction block with a joining strap to the other junction block. Redundancy? or is there not supposed to be a jumper from one block to the other. Making one block 12volt and the other 24 volt.
Sorry for the long post
