Results 1 to 2 of 2
Thread: Pop a precup
    Sep 2007
    Unhappy Pop a precup
    Well got the heads off both had badly cracked precupS and one had came apart, thats where the water came from. NOW WHAT TO DO,, new heads, one new piston, or used motor, too much for a rebuild, the engine ran great, good oil pressure, no oil consumption and looked pretty good other than a few dings in the BACK piston. Any suggestion should i fix this engine or go for another one.
    [B]93 ck 3500 247k new paint,poppy red airaid, 4in exh,quages, 1/6 turned up ip, little timing. 35k on block, new heads, injectors, turbo, turbo master, red neck caddy, continental package
    Where'd the water come from? Head gasket? Cracked head?
    If the cylinder wall isn't damaged (unrepairable), replace/repair what is damaged and throw it back together. Be sure to check all components of that cylinder for damage. Cracks in the cups is normal. As long as the cracks don't cross the fire ring or a chunk isn't about to come out (or came out), they're fine. Snap some pics of it and we can tell you if they are OK. (white crayon or chalk helps get the cracks to show up for the pic)
