Thread: Diesel Astro Van
    Nov 2007
    Default Diesel Astro Van
    newbie here on a quest to install a 6.2 in my astro this is what i have so far
    it does fit beleive it or not
    Welcome to the Forums!
    Sounds like a fun project. Is the block the same color as the valve covers? Can't see the block. If so, it's a 1982. DO NOT let that engine get out of your hands!! If it needs rebuilding, rebuild it. Do not replace that block (unless you break it in two, that is). The 82 blocks are much sought after for durability. The iron contains a higher nickel content not seen until nearly 20 years later.
    Nov 2007
    the motor was a freebie how do i tell what year the motor is
