Yep!
Originally Posted by
street_xr
Hi Journeyman,
Thanks for the info. In the case of the 1997, or other vehicles that already have a diesel and 4l80e I'm thinking the solution is to put the mechanical injection pump in and carry a spare PCM in case of failure. Seems like the going rate for used PCMs is around $ 100, much less than the $ 700 TCI unit. I can see the value of the TCI for standalone use though. Cheers, street_xr
Yes, best to use what you have w/TPS mounted to DB2, or DB4. T-stat housing can stay by making throttle cable bracket that mounts to top right (drivers side) bolt of stat housing. TPS and throttle cable bracket mods can be found in members area.
