I've been reading all the 6.2 / 6.5 posts and discussions, and perhaps I'm missing the relevant threads, but . . . .
Truck in question is my 1982 CC DRW 6.2. I have an NV4500 to replace the TH400, diffs have 4.10 gears. Right now I can get a '93 6.5TD donor truck with 210,000MI for $800.
Some of you have done a 6.5 turbo on the 6.2; others the turbo and heads, sometimes an IP upgrade to the late model DB2. Still others just swap the entire engine out.
What are the advantages to retaining the 6.2 block? Max RPM is slightly higher, CR is barely higher than the 93 but that's a disadvantage with the turbo from what I'm reading. 6.5 block gives me a serpentine belt without any effort, not sure how relevant that is. I've never personally seen a 6.2 with problems other than poor maintenance, and I've seen good and bad 6.5's, some real lemons. I've also read that acquiring a good 6.5 block sometimes requires a bit of black magic, i.e. cross your fingers and Magnaflux. I also understand the differences between the pre-cups for different years of 6.2 and the 6.5s.
Anyway, I'd love to hear some specific, technical 'splanations from both 6.2 and 6.5 proponents as to why they prefer one engine over the other and why. Please do include details as to your objectives (power, mileage) and usage habits.
