6.2 power into a Land Rover Discovery
Hi,
Put some pics in the photo forum and was asked to put more info here so here goes
1995 Land Rover Discovery UK spec right hand drive originally had 2.5 TDi
It has a 6.2 of unknown year, it has "V" belts and no EGR so an early one, just had one new head, new piston rings and a general overhall
Adapter plate mates it to a ZF 4HP22 4-speed autobox, with a 1800rpm stall converter, with lock up.
It has a Borg Warner chain-driven transfer box, incorporating a viscous differential lock with a high range ratio of 1.206:1 and a low range of 3.244:1
It is permenant 4 wheel drive and runs through 3.54:1 diffs.
Tyres are 225/75/16 on color matched Range Rover alloys.
Runs at about 2100rpm at 70mph and at that speed does about 28mpg (thats english gallons so a little less for US gallons)
Its 0-60mph is about 10.5 secs, gets to 90mph+ with ease.
Has uprated front coil springs to handle the extra weight of the engine.
The air cleaner is from a Mercedes V8, heavily modified to sit low over the intake, the alternator and power steering are the original Land Rover held on with fabricated mounts, the viscous fan has been removed and replaced with an electric fan, running from a sensor tapped into the rear of the inlet manifold, new high capacity radiator, 83*c thermostat. Cast exhaust manifolds into modified Land Rover V8 down pipes, then 2 into 1 stainless through a center powerflow box, then back into 2 3inch tail pipes. Electric lift pump with manual primer, rear and front filters. Twin 12volt batteries.
This is a base model Discovery so has cloth seats, no air con or cruise, no airbags, so it is in the "keep it simple" bracket and hopefully will not have too much go wrong with it.
Drives very well, feels stock, transmission is snatch free, pulls well and changes smoothly, has discs all round, vented at the front, so stops with no fuss, all in all a great truck, it has the performance of the 3.9 V8 petrol (14mpg 11secs 0-60) with the economy of the 2.5 turbo diesel (27mpg but 17.5sec 0-60)
The reason for 379ci on the boot and not 6.2 is that over here it is getting difficult to drive any 4X4 without it getting damaged whilst parked because of how environmentally UNfriendly it is, if I put 6.2 on the boot it would be impossible to drive it anywhere without getting lynched...... Most people don't know what 379ci is... they think its a model number...
Anyone want to know any more then let me know
Pete
1995 Land Rover Discovery with a proper engine.... 6.2 n/a mated to ZF 4HP22 4-speed autobox with a Borg Warner chain-driven transfer box, incorporating a viscous differential lock, permenant 4X4
