Results 1 to 6 of 6
Thread: Rear sway bar & traction bar?
    DA BIG ONE Guest
    Thinking of going w/rear sway & traction bar. Hellwig comes to mind for the sway but I'm want traction bars that will mount above the diff and spring so I don't lose any ground clearance.
    I've got more body roll than I like.
    The rear differential when off road will bounce losing traction if I get on it too hard from a dead stop.
    I have the Hellwig rear bar for the K2500. When I installed it a couple of years ago the kit was very poor design and quality in my opinion. It had bad or missing hardware, poor paint, and oversized holes for the bolts. I used my own hardware and brackets. The bar does not extend past the differential housing.
    1999 K2500 Suburban LT w/3.73 gears
    265/75/16 Bridgestone Dueler A/T Revos
    SS oil lines & HB7 cooler
    More to come...
    DA BIG ONE Guest
    How about function?
    I also have an ORU front bar that I installed at the same time. I just checked ORU's site and couldn't find it. Anyways, I did both bars together and I did notice better manners on the highway, which was what I was after. I primarily use my sub for family road trips w/ little or no off-roading. I run 265/75/16 LTX A/T tires on 16x7 Alcoa classic wheels.
    The sub doesn't seem to get blown around like it used to and the cornering is much flatter. I can really tell a difference on off-ramps - not a scary proposition anymore. Turn in is much improved. Overall handling is ideal for what I use the suburban for - highway cruising.
    I have not talked to anyone who has used these bars in addition to larger lift/tires. Also, I'm not sure how much the rear bar contributed to the end result. Together, the bars seem like the ticket for our trucks.
    More to come...
    DA BIG ONE Guest
    It's the off ramps and highway manners that I need to tame.
    I've come up with quick disconnects for swaybar end links when doing serious offroad activity.
    Sway/traction bars will help with the body roll.
    Traction issues on the rear is a tire pressure issue. If you are running them at full recommended pressure, it is very likely they will hop, chatter, bounce, and/or lose traction on takeoff.
