Is this engine now available to the gneral public? Any field testing? results of installing them in our Chevy trucks?
2004 2500HD LT Duramax LLY+Allison 2WD Extended Cab SB
Cooper LTX265/75R16 tires
Email vernj4@juno.com
The 6500 is available and will directly bolt in and go right to work.
AMG/GEP has done the testing and such as these engines for the HMMWV
The engine can be purchased as a complete long block.
Robyn
Any news yet about the newest version from the 6500?
Chevy Nova sedan 1977
6.5 HD diesel/ 4L80e
Gear drive timing set
Ram air, E.P.S. stainless steel exhaust
2.73 axle ratio/ 205-65-R15 tires
new projeckt: Dodge W200 with Detroit 6V-92
Jim (More Power) can bring you up to speed on any new stuff on these.
Drop him a PM
Robyn
They have 2 versions over the road hi-compression and marine low-compression
http://www.peninsularengine.com/
When I bought my Peninsular AMG last year I was told all their engines come with 18.1:1 pistons, but then it could have been in context of my getting one for the motorhome. At the time the web site didn't show the higher-perfromance engines, so maybe that's changed.
