QUESTION:
- Can bad injectors cause a noise that sounds like a knock, like a problem with the rod end bearings?
Would appreciate some input.
Thanks in advance and HAPPY HOLIDAYS.
QUESTION:
'96 Chevy Suburban LT 2500, 4x4, 6.5L Turbo Diesel, 4.10 Rear, 175K miles
*** Towing 26' ft. Travel Trailer (6,165 lbs DRY) ***
- aFe Stage 2 Performance Air Intake Kit
- 4" inch Jerry Jardine, PINNACLE POWER EXHAUST, 5" inch Chrome Tip
- 2-1/2" inch Crossover Pipe, mandrel bent
- KENNEDY remote mounted PMD/FSD Cooler Package, DTech PMD
- AUTOMETER Triple Gauge Pillar (Boost, EGT/Pyro, Trans. Temp.)
- HEATH Turbo-Master
- HEATH Max-E-Tork PCM
- PRODIGY Brake Controller
- BILSTEIN Shocks
- Forged WELD RACING Rims
- 265x75 R16 BF GOODRICH All-Terrain T/A's
If your Diesel engine is making a noise that would be like a rod in a gasser, 99% of the time it's an injector, or at least fuel delivery related. That is not to say Diesel engines don't lose rods. If that happens, it is usually pretty catastrophic, and the noise is the smaller indicator.
Thank you very much!
- BILSTEIN Shocks
