Hi all – once again, I find myself in need of assistance from the cyber-diesel community!
The problem I’m experiencing is fuel delivery, and I’m hoping it’s simply the lift pump, but suspect it may be a little more drastic. Following is a description of what I have, what the problem is, and what I’ve done to-date. As I’m beginning to test the limits of my normally very understanding wife, any suggestions would be greatly appreciated
The Truck - 1984 GMC 3+3 4x4 converted to diesel 4 years ago, 1991 “J” 6.2, 18:1 compression, DB2 injection pump, and Banks Turbo. Two fuel filters, OEM (located on the back of the intake manifold - what a pain to get to for changing!) and a Racor R60S. The racor filter is primary (fuel enters it first) and the OEM is secondary. Mechanical lift pump.
The Problem – From a normal running condition, the engine will begin to surge in gear, in neutral you can see (and hear!) the RPM jumping by a good 1000 – 1500 RPM. It will do this a few times, and then the engine will die. Let it set for 3-5 minutes and it will start back – sometimes with only a few cranks and other times with a lot of cranking. After starting it may run for 3-10 minutes and then surge and die again, or it may die right away.
What I’ve done so far – This is the second time I’ve had this problem. The first time was about 6 months ago (and it was about 50 degrees warmer as well). I had a small fuel leak in one of the fuel lines, and I hadn’t changed filters in quite a while. I replaced the leaking fuel line, and also changed the R60S fuel filter (no sign of water in fuel). I did not change the OEM filter at that time. After making those changes, everything ran great…till two weeks ago.
The exact same symptoms started again two weeks ago. After limping home, I changed both fuel filters and looked for, but didn’t find, any fuel leaks (thinking possible air in fuel lines?). After changing the filters and dealing with an air lock in the lines (changed both filters at same time…oops!), all ran well for a week.
Last week the exact symptoms started again! I managed to get home, but haven’t moved it since.
When I changed the filter this last time, I did notice some particles in the filter bowl that suggested possible corrosion in the fuel tanks. There wasn’t a lot – just enough to notice it. I don’t think that the new fuel filter would have clogged that quickly…but it’s possible. I’m also not sure what I have in the fuel tanks at the inlet – there may be a filter (i.e. bag on end of pickup), but not sure – they were originally gas tanks before the conversion to diesel.
What I’m looking to do next – I suspect I have corrosion in the tanks, but do not like the prospect of dropping the tanks (no way truck would fit in garage…it’s ranging from 10-20 degrees at our place this time of year). I guess it’s also possible that the mechanical lift pump is failing...my next steps are to install an electric lift pump and see the results. If the results are the same, the next step is to drop one tank, inspect, clean…hopefully not replace, but we’ll see! After dealing with the one tank, I’ll disable the dual tank switch and run off the one tank until the problem is resolved.
I did just read the “finding air” sticky…I will give that a try as well – wouldn’t it be nice if that was all it was
As always...THANKS All!
(Oh yea...Happy Holidays!!!)
