Used Motor Oil as Pump Lube
All,
I've read posts from my esteemed colleagues here somewhere (could not find in numerous searches) who are using used motor oil in the diesel as DIJ pump lube. I tried this in the fleet last week and was simply amazed how much quieter and smoother both are now idling. The Tahoe is also starting faster.
My question for those doing this: what method are you using to filter the used motor oil?
This batch I used was simply double settled, that is settled in the catch tank, then the top portion poured into a second clean tank and settled again and then the top of the 2nd tank captured for the pouring into the tank. I think the month of each settling time shook down most of the contaminants but I envision a strainer/colander with a home-made giant paper-towel as coffee filter inside the colander might be my 'polishing' filter. But, I rely on you folks heavily so as not to reinvent a process someone has already refined.
Thanks and Happy A.D. 2008
Mark Magee
98 Burb 2500 LT 4x4 VIN G, 4:10's 180K miles, Amsoil Bypass/full flow filters, Turbo Master, Heath ECU Reflash, Duraterm GP's, New Injectors, Walbro FRC-13 LP, 480LE Rebuilt 2X, Vacuum Pump Delete, K&N Filter, Fluid Damper, DTech remote bumper mount PMD, Kennedy Exhaust, Kennedy Fan Clutch, Robertshaw 192F stats, 2.5" Crossover, CAT gutted, Fumoto Drain, Alcoa Centerline Wheels, Ride Rite Airbags.
2013 Keyston Fuzion 301 Toyhauler 9,100#s empty
Velocity XLFG N34XL
Brady Texas Hill Country
