My 1994 C2500 Suburban all of a sudden wouldn't start the other day. It actually "tries" to start for about 1-2 seconds, blows a huge black smoke cloud, and shuts right back down. Temp was +/- 60 degress. I let the glow plugs cycle on & off a few times and tried again ... same problem. I noticed I could't move the wastgate arm at all, (even after an overnight Liquid Wrench soaking) so we pulled off the GM-4 Turbo. Even cold, the GM-4 impellor thing doesn't seem to have much play. After Turbo removal and "working" : the wastgate control arm I finally got it to work pretty good. In the meantime, I replaced all the Glow Plugs and will also replace the Fuel injectors once the install kit arrives. Batteries are both about 6 months new but I will put the trickle charger on tomorrow just to make sure they are ok. I will also clean up the 2 neg battery connectors tomorrow.
My question(s) are: 1) could the stuck wastegate controller cause all the black smoke and a no start condition? 2) Will the actuator just freeze up again real soon? (it seems expensive and silly to replace the whole turbo just because the wastegate got stuck!)
I'm also thinking about changing out the GP Relay/Controller since the intial cycle time seemed much shorter than it used to be.
I'm really, really, really hoping the IP hasn't gone bad. I recently had the IP replaced on my other Suburban 6.5TD (the 1999) and got hit for just over $2,000 for the repair!! Big ouch for me, I don't have that kind of moola.
All suggestions really appreciated.
PS I have a Multi Meter and now may ned to learn how to use it. I'm also going to order a vacuum tester which I will also have to learn.
Bruce De Mille
Lakewood Village California
1994 Chevy C2500 6.5TD Suburban
1999 Chevy C2500 6.5TD Suburban
