Coolant Leak?
Hello All,
My 2000 6.5 developed a coolant leak some where in the back of the engine on the right side. I took the starter off and lowered the bell housing cover to get a closer look. As near as I can see, there is no residue of coolant between the head and the block. I have felt around and looked for discoloration. It seems to be coming from where the tranny and the engine mate. I cant see for sure, but the coolant leak seems to be coming from in there. I have looked all over with a mirror but cant see anything. A bore scope is the only way to see in there as far as I can tell. This is the only location that it shows up at. After driving for 40 min, there is a cup of 1/4 " to 1/2" of clean coolant, no other colors and the oil is black, no indication of internal leaking. This happens every trip. Once the engine sits for a while, it stops, no more leaking. It is not a constant leak either. I hate to pull the engine if I don't have too. Not to mention thats where it will get expensive. Has any one else had this problem. Any advise would be greatly appreciated.
Thank you!
00 K3500 SRW longbox crewcab, P400, JK Exhaust, JK TD-Max boost controller, Remote CCV Filtration system, Intercooler, Airlift bags, EGR rear disc brake conversion, X-monitor piller mount, LT255/85R16, Gearvendors overdrive, unifilter, Remote PMD.
99 K2500 6.5 Suburban JK exhaust, Boost and Pyro gages
