Need an extended harness
You can leave old one mounted to pump.
Unplugging the harness requires you use a long screwdriver to release the harness plug tab then gently pull it off and maybe a coat hanger formed into a hook to bring plug to point were you can reach it but it will not come up and out to far but far enough to allow the plugging of an extended harness.
From here you need and extended harness JK sells em.
Then new unit mounted on a heat sink and mounted out of engine bay.
